This Audi A6 model received a facelift in 2001 for both sedan and Avant versions. The revised A6 sedan featured a new grille design and different headlights, while also being fitted with a wide range of petrol and diesel engine configurations. Most of these powerplants received a boost in power outputs.
Radio isn’t getting power.
What do I do if my radio isn’t getting power
Update (08/28/2022)
@oldturkey03 I checked the fuses that are on the side of my dashboard and they have power I was told to check if the wire had power going to it but it didn’t.
Update (08/28/2022)
Yes the radio is factory.
@juanherna use the wiring diagram to see what is going on with your radio. The fuse box on the L side has fuse #37 which is the radio fuse. It is a 20amp fuse so make sure you only use a 20 amp to replace it. After that trace the power wiring and see where is stops.
Juan hernandez crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 936
