Repair and additional information for the GE Profile Refrigerator PYD22KYN, a compact, built-in refrigerator with a bottom-mounted freezer, automatic ice maker, and door service feature, introduced in 2019. This page covers information for model numbers matching the pattern PYD22KYN****.
Refrigerator and freezer both stopped cooling
GE Profile Model PYD22KYNCFS stopped cooling both frig and freezer. I cleaned the condenser fan grille and the fan is running. Both the fan in the frig and in the freezer are running. The compressor was warm but could not really tell if it was running so I changed the starter and capacitor, that was no help .The copper tubing from the compressor is cool but not cold. I think it could be a temperature control problem but I'm do not know how to check that. If that is not the problem what do you think it could be? I was thinking a leak in refrigerant but I see no signs of there being a leak, no oils anywhere I can see. Please help send me in the right direction on this. The frig is 1.5 years old
Thank you
Hi @jeffbtlv
Here's the mini manual for the refrigerator.
Try running the diagnostics and check if any error codes are displayed.
Hopefully it is not a sealed system problem.
If it is check the warranty. Usually there is a 5 or 10 year warranty on the sealed system
Thank you so much! Do I have to run each test individually or does it run them all automatically?
@jeffbtlv
Each test has to be run individually by using the up/down buttons to step to the desired test
Thank you and have a great day!
Jeff crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 145
