Hi
Assuming that you are definitely using the right cable it should work
Some cables a built with a tolerance
For example if it’s half a millimetre too big it’s ok or if it’s half a millimetre too small it’s ok But that’s just a example and not actual information to go off of ,just a example
It might seem like it’s not fitting but if you get it in at the perfect spot it should fit ,but if it’s clearly not fitting don’t try it as it may cause damage
If you are having absolutely no luck follow this amazing guide to add some photos of it so we can see what’s going on a bit better:-)
Adding images to an existing question
Hopefully this helps
Any questions please ask
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
2
