This is an older equipment line from Saeco. All are labeled Sup 018. (Badge on the bottom). They were later sold under the name Spidem Trevi
accidentally pour water into the coffee grinder
accidentally pour water into the coffee grinder on saeco vienna deluxe sup028
due to pandemic , didn't take to repair, i didn't use the machine for 3 yrs since then.
most likely the grinder new to replace it.
No need to replace the grinder. It just needs to be dried out and I think 3 years is more than enough time. A good cleaning and you should be good to go. Make sure you remove all the old ground coffee. I have done this early in the morning years ago with the same model and it is still working fine
nancy crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 188
