Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
How do I fix a loose charging port without replacement?
The charging cable was pulled at an angle and it wasn't removed properly. Now when a charging cable is inserted, it goes in but there is no audible click and is loosely fitting. Is there a way to fix this without a port replacement? Is there a way to bend something in the connector so it grips the lightning plug more?
I think it's the wings inside of the lighting plug that are loose but is there a way to bend it inward without a device disassembly? I have a photo of what I am referring to below.
Hi
You to use a pair of fine tip tweezers to clean out the charging port as this can cause the charger not to sit right
As for the metal pins you mentioned you could try and bend them out with tweezers but I don’t recommend it as you could damage the port further and it might be more that the port is deformed rather than a bent component
Apart from that I would replace the port as they aren’t that hard and very inexpensive on sites like eBay
Hopefully this helps
Any questions please ask
This will help you
https://howtofixgadgets.com/iphone-charg...
I was also having the issue but i got a solution, That’s to clean my charging port i cleaned it with a brush and now my problem is thankfully solved. In apple charging port replacement cost is 10 - 20 dollars.
Replace the port, once it’s damaged it’ll never be the same. Easy enough to replace.
I recommend Getting A Volta Charger,
And putting the port adapter in the port forever Via Super glue or tape
Part: https://www.voltacharger.com/products/vo...
But Keep in mind @hellomacos 's answer is more practical,
And you won't have wired headphones anymore
crwdns2886500:0Custom cut rolls of Tesa 61395 double-sided tape for repair.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
Tesa 61395 Tape
$5.99
Please don’t superglue your phone. It’s much easier and cleaner to change the port. Loads of posts and videos on how to replace it. 👍
If the charging port on your device has been damaged and is no longer gripping the charging cable properly, it is possible that the port may need to be replaced. Attempting to bend something in the connector or otherwise fix it yourself may cause further damage to the port or the cable, and may not solve the problem.
jimmysofat6864 crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 62
crwdns2936753:030crwdne2936753:0 364
crwdns2942667:0crwdne2942667:0 16,811
