Hi,
Check that you have the correct oil filter installed and also the correct grade of oil as this could affect the flow of oil through the engine..
You may have to get the engine oil pump tested (oil pressure test) to check if the oil pump is OK or if there is something else wrong with the lubrication system in the engine.
It is better to get it tested as you don't want to be running an engine that has potential lubrication problems as it may overheat and damage could occur
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
