Phone went off few hours after battery replacent.
Hello there. Two days ago i used the guide to replace battery. I used 99,8 isopropyl alcohol to remove the adhesive. I used syringe to pour carefully and waited till i remove the battery. After that i replaced with the new battery (original samsung). I put everything back as the guide asked. I powered my phone and everything worked fine. I used it for 6 hours and then i went to sleep. In the morning my phone screen was dead. When i press power and volume down i feel a vibration but nothing else. Any ideas?
Hi
What happens if you connect the charger, does the phone indicate that it is charging?
Can you turn on the phone after a little while (to allow the battery to charge a bit) with the charger on?
crwdns2934271:0crwdnd2934271:0 jayeff crwdne2934271:0
Hi, the phone seems that is working because when i press power and volume down i feel the vibration but no display at all
crwdns2934271:0crwdnd2934271:0 Stelios Gkournelos crwdne2934271:0
@Stelios Gkournelos
You may have to open it up again and check your work and that the connections are all OK etc.
After the battery replacement it worked fin for 7 hours. Today the display showed some green horizontal lines and nothing else
@Stelios Gkournelos
Doesn't mean that something didn't come loose after it worked for a while.
I would check the display flex cable connection and also perhaps clean the cable end with 99.8 % IPA just in case handling it caused a bad electrical connection e.g. perspiration from fingers etc which prevents the screen from working properly
crwdns2934275:02crwdne2934275:0
