The Razer Blade RZ09-0102 is a 14 inch gaming laptop that was manufactured by Razer in 2013. It is also referred to as the Razer Blade 2013.
Why laptop is not turning on?
I have razer motherboard rz09-0327. I have checked the voltage lines, every voltage rail is present, when I press the button on the mother board fans spins, gpu and cpu get warm and everything shuts after approximately 5 seconds, but there is nothing on the diplay. And battery getting charged as well, I tested the voltage. There are no shorts that I could find. What might be the problem? Or where else I have to look?
Hi @dmakhmammadov
Try a power refresh and check if that resolves the problem, in case it is a corrupted BIOS that is the cause of the problem.
  • Disconnect the charger if connected.
  • Open the laptop and disconnect the battery from the motherboard. (you don't have to remove the battery, just disconnect it). Here's a video that may help. Not your exact model but hopefully it is close enough to help.
  • Press and hold the laptop's Power On button for a full 30 seconds and then release it. This should reset the BIOS back to its factory default settings.
  • Reconnect the battery and reassemble the laptop.
  • Connect the charger and try turning it on.
Diyorbek Makhammadov crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 926
