The smaller of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
How to fix power button again after accidentally removing it
So İ accidentally broke off the power button on my Air and when İ tried putting it in İ may have lost a metal piece and now it wont work
İ also have another Air with no OS and a cracked screen
Should İ salvage parts and then put the missing keys from my old housing and then use it that way or take the screen off my Air with dead power button with SSD
That mac has important stuff in it
İt has very old pictures that İ want
Or should İ ignore because my old 6 Plus has the pictures too
Keyboards keys are delicate! I would focus on swapping out the damaged parts to the good upper case system (broken screen) or just replace the MacBook Air 11" (Mid 2013-Early 2015) Upper Case part. Basically, transferring the parts to the good upper case. Here's the guide MacBook Air 11" Mid 2013 Upper Case Replacement
Given the age of your system I'm sure your battery is not very healthy if its still the original!
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
Here's the needed battery if you know its time MacBook Air 11" (Mid 2011-Early 2015) Battery and the guide MacBook Air 11" Mid 2013 Battery Replacement
crwdns2886500:0Replace an upper case compatible with the Mid 2013 to Early 2015 11 inch MacBook Air laptop. Includes the keyboard, palmrest area, and power button.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$69.99
crwdns2886500:0Replace a 5100 mAh battery compatible with the MacBook Air 11" Mid 2011 to Early 2015 A1370 and A1465 model laptop. 38.75 Watt Hours (Wh). 7.6 Volts (V). Battery model A1495.crwdne2886500:0
$49.99
crwdns2886500:0MacBook Air 11" Mid 2013 Batterycrwdne2886500:0
crwdns2930805:0crwdne2930805:0
crwdns2934079:0crwdne2934079:0
crwdns2937801:0crwdne2937801:0
10 - 20 minutes
crwdns2886500:0MacBook Air 11" Mid 2013 Upper Casecrwdne2886500:0
crwdns2937803:0crwdne2937803:0
4 - 6 hours
crwdns2886500:0iFixitcrwdne2886500:0
crwdns2937585:0crwdne2937585:0
2 - 5 minutes
KAAN CAN crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 153
