Released in 2020. Model Name GeForce RTX™ 3060 Ti VENTUS 2X OC Graphics Processing Unit NVIDIA® GeForce RTX™ 3060 Ti Interface PCI Express® Gen 4 CUDA® CORES 4864 Core Clocks Boost: 1695 MHz Memory Speed 14 Gbps Memory 8GB GDDR6 Memory Bus 256-bit Output.
Thermal Pad replacement thickness
Does anyone know the thickness of the thermal pads?
Unfortunately, I cannot find anything on the specific thickness of the thermal pad, but I did find an article on finding the best fit for your GPU. I'll link it here for your viewing, but I'll give you the spark-notes of it.
Ideally, you should use the thinnest thermal pad that you can with the device. Start with a 2mm thermal pad, and if it has an indentation from the heatsink go down a size of thickness. The material that you use also matters, as some materials dissipate heat better than others.
João Fonseca crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 84
crwdns2942667:0crwdne2942667:0 6,815
