This is the AMD Ryzen variant of the IdeaPad Flex 5. This page contains repair and maintenance information related to the Lenovo IdeaPad Flex 5 14ARE05.
Lid sensor not working properly
I have a problem with the lid sensor.
When i close the lid, the device won't go into the sleep mode. I have tweaked with the windows settings and the BIOS and it's not from either of them. I have downloaded the lenovo diagnostics tool and it revealed an issue with the lid sensor.
when i close the lid, the device won't go to sleep, but if i give it a couple of knocks on where the magnets are, it sometimes would shut and go to sleep.
i have opened it and the magnets are in place but i couldn't find the lid sensor around the battery. I think the sensor might be located in the screen but I still don't know.
Hi,
If the magnets are in place, did you check directly opposite the magnets if the sensor is there? It shouldn't be too far away from being directly opposite to where the magnets are. With the laptop turned on and with the lid open run a magnet over the area where you think the sensor should be and check if the screen turns off -i.e. simulates the lid closed. If the screen turns off you're close to the sensor. Hopefully it will be working long enough for you to find it if you have to tap to make it work.
I can't find a free schematic download online but IF you have a Lenovo IdeaPad Flex 5 14ARE05 and IF the motherboard model number is FLMA0 LA-J710P then here's a link to a supplier that you can buy it from.
The schematic won't show the location of the lid sensor but it will show you the component on the schematic drawing along with its component type details etc.
If you can't find the sensor by what is printed on the sensor itself as shown by the schematics then you should be able to track down where it is by seeing what other component it connects to and tracing back from it.
Just what I'd try.
thank you!!!
x-hellboy-x crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 121
crwdns2942667:0crwdne2942667:0 5,702
