Repair information and guides for the iPhone 8 that was released on September 22, 2017. Model: A1863, A1905
Phone overheating after battery change
I replaced the battery on an iPhone 8 (ifixit battery) when I start up the phone, everything appears to work but after some time the phone gets hot - realy hot.
I'm not sure where the heat is coming from and I don't want to open it up again unless it's really necessary.
Hi
If it’s heating up I would try a and reseat all the connectors you disconnected and clean them with isopropyl alcohol while you are there
As for finding the fault so would get a microfibre cloth and dip it in isopropyl alcohol not so it’s dripping by enough
Then wipe the device and see where the alcohol evaporated first as that will point you to where it’s heating up and you can address it accordingly
Hopefully this helps
I’ve just had the same issue. Replaced iPhone 8 battery with ifixit replacement battery today. No problem swapping out batteries but as soon as I plugged it in to charge it overheated and didn’t show charging bar. I disconnected, reopened case and checked all connectors. Reconnected and sealed casing and reconnected charging but now nothing. Any ideas?
Well I will suggest you to try a different charger to charge your phone and also check for any kind of malware in your phone.
Pavle Spasic crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 234
