not draining and spinning
tp load Maytag does not drain and spin, but if I manually turn the dial to spin cycle, it drains and spins perfectly. Dial need cleaned?
Hi,
Sounds like the timer (part #WP21001522) may be the problem. Either a worn contact operating cam or a faulty (dirty?) contact.
Unfortunately, they cannot be repaired, they have to be replaced. Search online using the part number only to find suppliers that suit you
Do not attempt to open the timer to fix it as you will have cams and contacts going everywhere once the case is opened.
You could try disconnecting the power from the machine and then accessing the timer and liberally spraying some contact cleaner (example only - there are others), in through any openings in the timer case, allowing it to fully dry (read directions on can) and then check if it now works OK. Do not use "regular" WD-40 as this leaves residues which may cause problems.
crwdns2942667:0crwdne2942667:0 436
Hi,
What is the model number of the washer?
crwdns2934271:0crwdnd2934271:0 jayeff crwdne2934271:0
Sorry I forgot yesterday. It's a Maytag Performa, model PAV2300AWW rev12. thanks Darrin
crwdns2934271:0crwdnd2934271:0 Darrin Fitzpatrick crwdne2934271:0
I know this has probably been repaired or replaced by now, but I recently had this problem with a Kenmore 110 which I believe is the same machine. I replace the start capacitor which is located on the motor at the bottom of the machine and that solved the problem.
Video can be found here.
https://www.youtube.com/watch?v=RNcTX3YY...
crwdns2934271:0crwdnd2934271:0 Jim crwdne2934271:0
