How to change the cable beats EP
My beats wire is not good and I need to replace it how can I do that
hey you can tear off the earpad,the side with the audio jack one,you ll need a hair dryer to help it remove easily ,then you ll see 4 screw,unscrew them and you can saw the audio wire. Use the multimeter to check continuity and solder the female connector.during this process you will need to extend the hole to contain the 3.5mm female connector and some ca glue to make it attach.
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 554
Hi
Is it the auxiliary jack end or the headphones end you want to replace?
crwdns2934271:0crwdnd2934271:0 HelloMacOS crwdne2934271:0
Auxiliary jack end
crwdns2934271:0crwdnd2934271:0 Lovekesh Jain 53 crwdne2934271:0
