Announced September 9th, 2014, this device is Apple's first foray into smart wearables. iFixit's repair manuals are applicable to Apple Watch (steel) and Apple Watch Sport (aluminum).
microphone is not working how to fix it
it gets a little wet in the rain since its microphone is not working.
how can we fix it?
Sadly its a bear to get it out to replace as you can see reviewing Step 13 here: Apple Watch Teardown
The next option is try cleaning it from the outside. Using a cotton swab (Q-Tip) wet it with 90% or better Isopropyl alcohol pressing the wet swab into the hole a few times to drip the alcohol into the hole. We don't want to insert anything into the hole as you could easily damage the microphone. Then using a can of can'ed air holding the nozzle a good 1/2 inch away from the hole directly inline one or two very short blasts to create a pressure wave to push the alcohol in then out. You may need to repeat a few times, testing the mic after each application.
Sadly this still might not work.
Syed Imaad Ali crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,164
