Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
Minimal set of connected components required for functioning.
Given an iPhone 5s logic board and associated home button, assumed to be partially or fully functional, what other components are necessary to attach in order to do the following:
a) boot the device
b) unlock the device
c) charge the device
d) extract the device's stored data to a computer
e) connect to a wi-fi network from the device
I'm hoping to avoid unnecessary expense in buying parts. Would having a working:
i) battery
ii) charging port assembly with headphone jack
and
iii) display assembly
suffice for all these functions? Would connecting additional components be required (which ones)? And is the display necessary in order to backup the data, given an USB OTG adaptor and external keyboard (assuming the OS version is <= 10)?
screen, port and battery. wifi wont be needed for extracting data.
Is it possible to skip the port for a wifi transfer, assuming the battery is already charged? What parts would be needed in that case, and how to turn it on?
@klutz you can turn it on by shorting pins on the power button connector but if your not confident in doing that then you will need a port or power button to turn it on
David crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 80
