Have vertical gray area from top to bottom, rest of screen works fine
. This is what it looks like. Rest of screen works and if you can "guess" under the gray, can click/select the item. Have done all the usual resets, etc. also changed the display cable. Probably something in display... can that be fixed or have to be replaced?
Update (06/17/2022)
So next time I fired the iMac up, it was not an all gray area, but partial top and bottom with a thin blue vertical line. So I used a screen grab of the area, including the missing data part) and it showed up fine. That should mean it is the display is defective. Sadly will order a replacement. Hope this is the right solution. Any comments folks?
@macman67 your screen lost complete contact with the ribbon cable that is coming from the driver board to the display. Since those are attached via a special bonding process, it is not a good DIY’er repair. Yes, replacing the display will be the prudent thing to do
Experienced repair, so will give it a try. Also order a replacement screen. Thanks.
Thanks, heat "rebonded" the cable on that section and all is well again. Thanks!
Carl Schultz crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 137
