The Keystone KSTAD70A 70-pint Dehumidifier removes up to 70 pints of humidity from the air per day.
How to swing the cooler air because it stuck one side
Plzz tell me itgotstuck one side
Rohit Agarwal what got stuck? You have a Keystone KSTAD70A 70-pint Dehumidifier? Give us more information. Things like what got stuck, how did it get stuck, what have you tried to fix it, will help us to help you.
@oldturkey03 no I have kenstar cooler
@Rohit Agarwal so a Kenstar Air cooler? What is stuck? What model is your air cooler?
There is a small ac motor which works.like car wiper remove plastic shaft check if all flaps or one of this flaps are blocked hard remove main rotating plastic rod or replace it without load check motor running ya not check rotation switch.. at last change rotation motor it cost 250 rs pull out motor replacement with same size motor
@rajeevpawar if you ever get some pictures of all of that, it would be awesome if you could add those to your question Adding images to an existing question
it would be neat to see this since we don't have a lot of guides on this.
There is small ac round type motor to swing flips
First check there is dust under flips move motor and on it seperately to check if motor works issue mey be dust or bend of any vertical flips
Motor work like wiper of car
Easily change at home click pic n upload Google lense simple issue u can get price dealer nearby u
Purchase online best option
Check dust between rotation particals end top ya bottom
Clean it if broken removed that flip
Check motor for rotate those
Small a.c volt motor works like a wiper to rotate flips
Simply use any lubricant both side of each flips ... Check voltage on motor from rotate switch... Enjoy
Rohit Agarwal crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 411
