The HP Officejet Pro 8600 Plus is identifiable by its model number: N911g. Released in 2011, the printer can be identified by its brown finish and touchscreen control panel.
Printer will no longer fax
My printer will no longer fax or answer. Line to printer tests good. Everything else works perfectly with the printer. When is goes to fax I get a notice that "unable to send or receive faxes".
I plugged the cord from the wall into an old fashioned phone.
What do you mean,"is the scan and fax method on"/
@jimwsr I read that in a google search about your problem. I have no idea what that is, and if you don't maybe that is your problem.
Hi @jimwsr ,
Try running the test fax setup from the printer control panel and check what it shows. See p.220 in the manual
define "LINE IS GOOD" and how you know?
Is the scan and fax method is ON?
James Wildgust, Sr. crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 438
