Repair guides and support for the eighth generation of Ford F-Series trucks: the F-150, F-250, F-350, and F-Super Duty.
Why are my brakes hard to stop
i have a 1993 ford f150 we changed brake booster and mastercylinder and put new brake calipers on it still have to stand on the brakes to get them to stop . its a automatic 4x4 truck also
Hi Liona,
Generally when something isn't working for me, one of my first questions is, does it have power? In the case of your power brakes, the "power" for the brake booster is vacuum. Since you've eliminated the booster itself by replacing it, if it's still not working, it sounds like it's not getting any power (vacuum).
From Vacuum Booster Diagnostics - Know Your Parts:
Inspect the vacuum hose to the booster for kinks, cracks or other damage. Check vacuum at idle with a vacuum gauge. To test booster function once the reserve is depleted, hold moderate pressure on the brake pedal and start the engine. If the booster is working properly, the pedal will drop slightly.
Unfortunately, the site I'm quoting from isn't coming up for me, but the snippet from Google search results has the basic information. If you have a vacuum gauge, check the vacuum at the booster and compare it to the vacuum where the hose goes into the engine. If there's a difference, then you've probably got a bad hose and that may be all that's needed to fix the problem. However, you can usually tell if a vacuum hose is bad just by examining it. Take it off and check both ends for splits or cracks that could be letting air into the booster and negating the vacuum. Flex the hose and look for tears or holes, especially at bends or any part that rubs on another piece of the engine.
Hi
I’m no car expert but I have seen some cars that need brake fluid injected to give them more power
I would check your local car garage or dealer ship to see if they will sell it to you or have it done
Hopefully this helps
First question is: 1. Is the pedal fading to the floor and the 'hard' you are describing is just that the pedal is at the floor? When replacing a master cylinder on these Fords, it can be a pain to properly 'bleed' the master cylinder and then the complete brake system. You don't mention the results from your bleeding after replacing the Master? Below is one of my videos on Master Cylinder Bleeding and my YouTube channel @Caddyman has a host of other videos dedicated in a Playlist to the repair of this 1991 F250 4x4 7.3l IDI. Enjoy.
https://youtu.be/51vcS0-FTAU?si=eTNJE7j0...
Liona Oxford crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 324
