Power button stuck in phone
Power button got stuck inside the phone
hi
iv only ever seen stuck buttons a couple of times but from what iv seen usually isopropyl alcohol and tooth picks usually work
if you can pull the button up with a tooth pic and then use a very small amount of alcohol to clean and loosen up debris
if this doesnt work you may have to open the device and clean the button manually
hopefully this works
Volume button stuck in phone
crwdns2942667:0crwdne2942667:0 3,828
