Released September 20, Apple's mainstream 2019 iPhone comes with a 6.1" LCD touchscreen, dual cameras, and six available colors. Successor to the iPhone XR.
My phone dropped in the toilet sinc
I mistakenly dropped my iPhone 11 in the toilet sinc and I removed it immediately I clean it with a towel I placed it horizontally for about 30 min after that I play some music on it and it work perfectly so some minutes later I charged it and when I remove it from charging its still good after some minutes it won't touch some part and it wi touch again after using it that way for some minutes I try to reboot it and when I reboot it a half and quarter part of the screen won't touch I can't even power it off and I can't unlock it please what can I do to fix it and can it be fixed
@feranmi it appears that what you have is a water damaged device. Time to treat it like that.
The very first thing you want to do is to stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse. This may further damage your phone.
The next thing to do is to clean it. Disassemble your phone using these guide iPhone 11 . You must remove all EMI shields. If you do not remove those, you might as well not do anything. After you remove those, clean the whole board, connectors and all, with +90% isopropyl alcohol. Follow this guide , and even so it was written for a 3G all the points are still pertinent to your phone. While you clean your board, check for any obvious damage, like burned or missing components etc. When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, change your battery and reassemble your phone and reevaluate. Until it is cleaned, everything will only be a guess. It is possible that you have a bad (water damaged) display assembly, replacing it may fix this. Even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try. If not sure about all of this I’d try to contact experts like @refectio or @imicrosoldering and see what they recommend.
Oldturkey is right. These are double layered boards and if the liquid got through to the logic board it will probably cause oxidation to the pads between the boards. If the liquid didn’t make it to the logic board I would replace the screen. I would also unplug all the connectors and lightly scrub isopropyl alcohol on the logic board connectors with a tooth brush.
Sorry to hear that. If it is wet then try a home remide, place it in the rice for 30 mint, rice will soke all the water and after that sprinker those rice to birds and your phone will start working
crwdns2889612:0crwdne2889612:0 -1
@lynnetteward around here we stay away from suggesting Rice. It does not work and there is no evidence that it ever has. Check on here for more info https://www.ifixit.com/News/30047/rice-i...
Feranmi crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 2,148
