Repair guides for displays (or monitors) for computers or other devices with video output.
Won't turn on? LG - 34UM95-P UltraWide
Hi,
I was wondering if someone could give me some advice? I've never fixed anything electrical and would like to give it a shot.
My LG - 34UM95-P UltraWide monitor stopped working earlier this week. It won't power on, the white LED light near the joystick at the bottom of the screen is no longer turning on - neither is the monitor itself.
I've changed the fuse in the plug, but no joy.
I've had a look online and it's taken me down a bit of rabbit hole, I found one post that suggests the issue might be related to a EEPROM chip, perhaps it needs replacing or rebooting?
Wondering what tools would be useful to get to try and fix this monitor?
The monitor is in great condition for its age - purchased in 2014 - it's not been knocked about, I think something has just burned out (I have no idea).
It might be unrelated, but worth mentioning. I mainly used it with a MacBook Pro connected via Thunderbolt port. Never had any issues with this. In the last year or so a second PC laptop has occasionally been used with the monitor. Connecting via HDMI.
Sometimes the HDMI connection seemed a bit shaky, the monitor would make a white noise/static sound almost as if it was cutting out but only for a split second. Trying other HDMI ports on the monitor didn't seem to make a difference. Unplugging the HDMI lead and giving it a blow seemed to temporarily fix it. It was very random.
The monitor finally stopped working after the PC laptop performed a windows update.
The PC laptop wouldn't connect to the monitor and the image on the laptop was jumping all over the place. The monitor was blank, no power. Not sure if this is related?
Hope someone can offer some advice.
UPDATE #1
I've managed to open the back of the monitor. Images attached.
UPDATE #2 - Saturday, May 28, 2022
Test power adapter
I've tested the power adapter, multimeter showed 19v. So at least I know that's working as expected.
Test connector
I was unable to get the red probe deep enough into the connector, so I put it on the metal coming out of the connector, see red circle below. The black probe on a screw on the board, see black circle in the image below.
The multimeter was set to resistance mode, and it beeped.
I also tried the multimeter on two other resistance settings. First on a setting of 200, the reading was 01.0 then I changed the setting to 2k, the reading was .001
Test connector with power cable
Set multimeter back to DC voltage mode, setting 20. Plugged power cable in and turned the power on. Black probe on the same screw as before, and red probe on L713 , gave me a solid reading of 19.20
crwdns2944067:06crwdne2944067:0
@stephenmeehan check our AC adapter and make sure that it supplies the proper voltage
I have a similar issue, but it's the jack. I have to push the power supply plugged into the jack to the side to get it to work. Previously, the monitor would cut to black occasionally, and I wasn't sure what it was. Not I know. Issue is I see no places to find a replacement power jack. Just power supplies.
Is there anything else I can try?
@Jordan Thompson thanks for your comment, is the power jack not part of the power supply? Or do you mean the jack on the board? If so, It’s possible to replace this. See links in this post.
@stephenmeehan I'm having similar issue, I wonder if you manage to fix the issue, and which part was failing? Thanks!
I fixed my monitor by reflashing firmwware on EEROM chip with dump file I found on on badcaps forum with CH341A programmer. As I have seen, a lot of these monitors have same issue, they just wont turn on. no sign of life. By just reflashing the EEROM chip problem can be solved. You even dont need to desolder the EEPROM chip, just hook up CH341a on to it and reflash it. Hope this helps.LG 34UM95 Badcaps thread, dump file, it says lg34um95-p but it works also on non p version.
i think i have same problem. can you give more details? also have whatsap 0040751437612, placed one order for CH341A programmer
Hi @stephenmeehan
I am almost certain that the issue is your power connector on the monitor. Especially because the white buzzing noise that you mentioned in your question.
These wider monitors usually operate on a 19V power supply with currents up to 3.5-4.5A. The connector is similar to a laptop DC IN connector with 2 inputs (V+ and GND) and usually they are soldered on the motherboard by 3 or 4 legs.
The static noise you heard was probably a leg come loose in that connector due to physical and/or electrical stress (almost 85Watts) at this tiny connector it may be burnt and/or broken and that is why the monitor is not turning on.
If you are able to take the monitor's back cover off and measure the input voltage, which should be 19V on the connector, you should see either 0V or a non stable voltage if you move the cable in the connector. If this is the source of the fault, you can desolder old connector and get a new one soldered in. If there was a short created by the loose connection at the power input, you may have a blown fuse on the motherboard as well.
Here's a link to a video on how to open the monitor:
https://www.youtube.com/watch?v=dlMphcRP...
Hope it helps!
crwdns2944067:013crwdne2944067:0:
Thanks for the reply, that gives me something to try!
I think I'll be able to take the back off the monitor, thanks for sharing the video.
Can you recommend a device for measuring the input voltage? and what I'd need to remove the broken part and re-solder it?
You would need a digital multimeter first to do your measurements (iFixit sells them )
Then a soldering iron if the problem is the connector. Try to get a 60Watts or higher just because of the thremal mass of the board you need to desolder the connector from.
Thanks.
Thinking of getting this set on Amazon. What do you think? It’s 60w
Deal: Tabiger Soldering Iron Kit, Soldering Kit with LCD Digital Multimeter, 60W Soldering Iron with 5 Extra Tips, Stand, Desoldering Pump, Solder, Wire Stripper Cutter, Tweezers, Tape, Tool Bag https://smile.amazon.co.uk/dp/B08KVYD7DK...
With this soldering iron
0.8mm Solder Wire, Lead Free Soldering Wire with Rosin Core Solder Tin Wire for Electrical Soldering Electronic Components Repair and DIY(20g) https://smile.amazon.co.uk/dp/B09XJRP1R9...
Where can I get replacement connectors from? Do you know the name of them?
@honakrisi
Did a reverse image search. Looks like that part is called a DC jack SA300. Appears to be a standard part used in many monitors.
https://www.aliexpress.com/item/32961447...
Looks good. Bargain for that price.
With lead free solder I would buy some sort of flux to help the flow of solder.
Connector is similar to this:
https://www.ebay.co.uk/itm/255487224090?...
crwdns2934275:08crwdne2934275:0
@stephenmeehan For now just start using the LG flowchart for the no power situation. If you show 19V on C764 you know your jack is okay and you can move past it.
Update (06/12/2022)
@stephenmeehan finally found the rest of it too. Check the IC's according to their required voltage. IC 703 and all the other IC's are pin 8 to be checked for the proper voltage. Looks like this beast (monitor:-) had issues with it's EEPROM. Looks like a lot of people(weirdly enough mostly Eastern European) flashed the EEPROM. Anyhow, this LG 34UM94 95 should help you getting your monitor back on the road :-)
That’s really helpful, thanks for sharing that.
@stephenmeehan of course. Check the IC's as outlined. Let us know what you find
Like the OP I found this very helpful & informative. What's the reason that only IC703 has voltage checked on pin 7 and all others in pin 8?
@electricfish Good catch. Just rechecked the schematic and they are all pin 8. Answer has been edited to reflect this information. Thanks @electricfish
Thanks for confirming. I have very little knowledge of electronics, limited to just-enough self taught for hobby.
Sadly I now see there's a tiny charred pitz since.of pinhead on a pin 2/3 of IC703.
Is this thing a goner? Multilayer PCB and all, I think it's done for, right?
SOLVED WON'T TURN ON - LG - 34UM95-P UltraWide
  • steps for glory ********
  • buy CH341A programmer with clamp, you will connect the clamp on the USB on 25 socket, check picture (it has 24 and 25, connect in the direction of picture below)
  • you will reprogram the chip EEPROM (BIOS) ML25L8006E - using the USB, the CLAMP, a software and a PC with windows
  • unplug your monitor LG 34UM95-P from wall 19V adapter
0-connect USB Programmer with clam on the chip correctly in pin 1 on the motherboard of the monitor LG 34um95-p
0b. LG monitor should be UNNPLUGED (not with 19v connected) - RED light on dongle will ON
1- INSTALL DRIVER WITH USB PROGRAMMER CONNECTED TO YOUR PC AND WITH SUCCESSFULL INSTALL
2- on software select DETECT
if ok will detect a few variations
3- SELECT ONLY ML25L8006E FOR LG 34UM95-P MONITOR
4 - READ: if ok will read actual firmware (100%) -- GREEN light on USB dongle will flash
5- SAVE: BACKUP OF ACTUAL FIRMWARE on your PC
6- press ERASE, then BLANK
7-READ AGAIN, you will see all FF and ...... of blank memory of the EEPROM CHIP
8 - OPEN and select NEW firmware working (from link) LG 34um95-p.bin
9- press WRITE ( and wait 100%) this will write new firmware
10-disconnect usb dongle from your pc
11-PLUG the monitor with 19v power adapter
12- it shoul work and POWER ON!!! :)))
software https://tecmikro.com/documentos-software...
firmware working LG 34um95-p.bin https://www.badcaps.net/filedata/fetch?i...
this is another exampled how to use USB (in this case on a motherboard pc)
Thank you for the tutorial, im trying to follow step by step however i got a few questions, you say to select "ML25L8006E" however from my end and your screenshot i see that is "MX25L8006E" im assuing is a typo, and when i try to erase then Blank i get an error "chip main memory are not null", and when i load the file and finish writing it i get "Chip Main Memory with the contents are in disagreement", any tips on what i can do? or what am i doing wrong? thank you.
See image attached - jpg
@electricfish yep, pretty gnarly. It is defininetly gone up in smoke ;-) The way IO would proceed is to desolder teh IC and clean teh board. Lets see if the solder pads are still good. If so, then you could actually try to fix it instead of replacing it. Once it is desolder and the board is clean, measure the voltage on pin 2, well in that case the solder pad where pin 2 connects to. You should have 19VDC on that. If you don't check on C724 for the voltage. Remember Black probe to ground and Red probe to test.
It really does not yet look dead yet. It's only dead if you say it is :-) Go for it. You got this. Let's give it a try to repair your board.
Repair is War on Entropy!
@electricfish here is the datasheet for the ICMP2315 Datasheet. The component is readily available at places like mouser.com digikey.com and many others. Cost around USD$3
Stephen Meehan crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 52
crwdns2936753:030crwdne2936753:0 196
crwdns2942667:0crwdne2942667:0 9,500
