The connector may not be the biggest problem, what does the board look like where it came from?
Here's some guidance on your query:
Recognizing & Disconnecting Cable Connectors
It is likely that the board was damaged missing or damaged pads, traces etc. A photo of the board (macro, clear) would help establish that. If so repair IS possible but I'd advise a professional instead at that point. Difficult needs specialized tools. But honestly it looks like you're already at that point. I shouldn't discourage you from making an attempt though, with good eyes a steady hand and the right tools and supplies you can probably do it. But it isn't easy. If the pads or traces are damaged I recommended a pro because with a microscope etc the job is not overwhelming. You can learn the techniques and if necessary cheats and tricks to get it working again there are lots of videos showing how. That will depend on you and maybe your finances. If you want to badly enough to learn how, good luck and let me know if I can help you further.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
2
