Repair for speakers, stereos, header units, and CD players for your car or truck.
no sound from speakers only sub works
my car speakers slowly stopped working one at a time so i replaced all 4 speakers and now i have no sound at all but the sub still works i also replaced the head unit. so it has new speakers and new head unit. i thought it was the wiring so i ohm tested the wires and got .5-1 ohm each i connected the speaker directy to the head unit and still no sound. any other things i can try
Are you currently running any amplifier which normally feeds your speakers? If so, when you connected the speakers directly to the head unit, was the amp also connected?
If you replaced the factory radio with a replacement head unit, it's possible there was a separate factory amplifier module in the car that was failing instead of the factory head unit. There are online resources to show you where a factory amplifier module might be for your vehicle. Older factory Bose systems are notorious for this. Aftermarket car stereo brands make amplifier bypass kits for some vehicles specifically for this problem.
Antonio Calderon crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 100
