Released September 21, 2018. Models: A1921, A2101, A2102, and A2104 / Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray (Pronounced "iPhone 10 S Max.")
crwdns2934591:0375crwdne2934591:0 crwdns2934593:0crwdne2934593:0
XS Max - back glass BROKE. What should I do?
I have the option to get a $30 back glass replacement, or a $100 back housing replacement. Since this is a rather old phone, I want to spend a minimal amount. Will glass replacement be okay?
back glass replacement is fine depending on who is doing it and what method they use to remove the old glass
The rear housing is what virtually every other part in the phone is mounted on, so replacing the rear housing isn't just any old part swap, but more like a complete disassemble and rebuild of the phone. If you can get away with just replacing the rear glass, definitely a far better option. As long as the case isn't bent or distorted, the glass can be professionally replaced to where you would never know it had been broken.
crwdns2942205:01crwdne2942205:0:
depends if its a pulled housing or a copy, copy back glass or glass of similar thickness. genuine housing with copy port. all leads to if its done by a good tech it should be fine
Chip Demise crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 70
