I have an Asus ROG GL503GE laptop. Recently the CPU side fan has been making scary grinding noise. I have searched almost everywhere to get a replacement fan, I contacted Asus customer care. None could help me, even the customer care representative said the model was very old and they had no replacement fan :(
I badly need to get this fan fixed. Any idea which types of fan will it support? The CPU fan's part number was: FCN DFS2013121A0T, rated at 12V 1A.
Try gently peeling off the label from the centre of the fan and see if you can see a bearing. There may or may not be a cap over it I don't know
If you can see it apply 1-2 drops only of light machine oil (sewing machine oil perhaps) to the bearing and see if this stops the noise.
Do not apply more than this as you don't want it running everywhere.
Replace the label in position when finished
Here's a video that may help as it shows how to access the fans once you have removed the cover etc. The fan label can be seen at 13 seconds into the video when the fans have been turned over.
Thank you for taking the time to look up. Unfortunately, I couldn't buy from any of the sources above (shipping cost is showing 200$+). I just need to replace the fan, but they are selling the whole heatsink
