2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
crwdns2934591:0774crwdne2934591:0 crwdns2934593:0crwdne2934593:0
power problem after battery replacement
I replaced the battery of my macbook pro 15" mid 2015 with a replacement from ifixit after it gave a recommendation to replace it and the battery life was terrible. No other issues with it. The macbook did it perfect for a few days and I was able to recharge it fully about 3 to 5 times.
Suddenly I have power issues with the following symptoms:
  • won't boot when on battery
  • on charger it will startup, but after login it will restart when bar hits around 30%
  • I managed once to somehow get in a few days later. Battery was charged to full and I tried again. No adapter. There was no error message about the battery, everything acted normally.
  • Next day, same problems again.
The thing which keeps popping in my head is that the voltage on the replacement battery was lower then the original battery. But the labeling of the battery said it was exactly for my model.
Any idea what I could do?
Hi
My advise would be to plug the old battery back in and see if the issue persists
If it goes away try cleaning the board and battery contacts with isopropyl alcohol
If the issue still persists contact ifixit there support team is amazing and will give you some of the best support out there
wow, that was a quick answer.
The old battery worked immediately. I reconnected the new battery and made sure it was well connected and at this moment all seems to be working again. Now I feel stupid for not thinking about it myself.
If the problem reoccurs I will clean the contacts like you suggested.
Hi
Don’t feel stupid about it
Iv made the same mistakes a couple times
Thanks for the reply:)
Thanks
nutstree crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 88
