Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
Replacing Nand Flash with higher capacity without restoring
As the title says, I want to replace the Nand without updating ios. Most threads I have seen is people having fail nand flash memory.
i have experience on how to replace its nand flash, but usually the new nand needs to be erased and programmed in order to work.
but my case is if I have a working 32gb nand and I want to upgrade 256gb nand. Can i clone the contents of 32gb to the other memory? Would that work? Because i dont want to hit ios 15 because theres no jb for that version
I also have the same problem, I wonder if it is possible with a nand programmer to extract a disk image file (encrypted of course) and then be able to flash it on a larger nad. This way the iPhone should recognize it as it is always encrypted, but I have no idea how to do it 🤯. @tomchai I think he can help us 😬
the data on the nand that the phone is using now needs copied to the new nand in order to work. you could download a lower ios and flash it using 3utool.
Wouldn’t it still need to be signed? Which would still leave you at 15.4.1 at the time of writing which has very little progress in terms of jailbreak.
NAND flash chips are inherently difficult to repair at the component level. In most cases, they are not designed to be replaced as standalone parts; instead, the entire logic board or storage subsystem must be replaced. From a cost–benefit perspective, the effort required to isolate, desolder, replace, and reprogram a NAND chip is generally unjustifiable for standard repair work.
Unless the repair is undertaken as a specialized project—such as forensic data recovery, research, or high-value device restoration—the labor, tooling, and expertise required outweigh the potential gains. Even when a physical replacement is possible, the new NAND must be programmed using proprietary or specialized software to write the correct firmware, calibration data, and system partitions onto the chip. Without this step, the device will not boot or function correctly.
ryeisqt crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 933
