My guess would be that the spilled drink damaged components on the TCON board, which is connected to the display by a host of flex cables. Or got into the eDP connector (which carries signals from the TCON board to the actual logic board) itself. More than likely that's going to require a new display at the minimum, since the TCON board is part of the display assembly, and is not easily replaced. Most of the flex cables which transmit signal to the display are soldered to it, hence why it's not an easy part to replace. And the cables themselves may also have sustained damage.
TL:DR this is more than likely a new screen sort of situation, or it's going to require repair which needs microsoldering level skills and a lot of care (repair of the TCON board is doable, but tricky since it's very easy to melt the flex cables and you need to desolder shields just to get at the components here).
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
3
Now i tried to use my external monitor but no signal is sent to the monitor it looks like. Could the liquid damage also be reason for this
crwdns2934271:0crwdnd2934271:0 Tobias kjeldsen crwdne2934271:0
