Repair guides and support for internal and external vehicle accessories including: chargers, luggage racks, aftermarket modifications, air conditioning and heating units.
Spares for Warrior air compressor
I have a 3HP V-Twin air compressor, made in China. It is badged Warrior, but I can't see any model number. I am trying to renovate this, and will no doubt need some spares if only gaskets and o-rings, but maybe also valves, piston rings etc. Does anyone know where I can get these from? Does anyone make generic spares for compressors? Or can I get spares from somewhere in China?
I have asked a number of UK compressor companies, and they all say "we don't deal with those compressors" or "those are obsolete in Europe".
Thank you - Rowan
I am still working on this. I managed to buy some new valve springs which seem to fit, and I bought some new piston rings that I think will fit. Many of the parts seem to be generic. I bought some new air filter enclosures which were said to have 16mm threads, but the thread is too large for my compressor. You can buy plastic filters with 15mm threads, which might (or might not) fit, but I prefer the metal filter enclosure, so I'm making some adapters with the correct thread on my lathe. We will see how this goes in due course. I bought some gaskets some of which seem to be more or less the right size, but will need a little trimming. The cylinder base gasket was completely wrong (the gasket has 4 screw holes but the cylinder base has only 2 screws). So I will try to cut new gaskets to fit (when the sheet of gasket material that I have ordered arrives). I did buy a cutting compass from Amazon that looks as if it should be good for cutting the larger holes in the gasket. For the small holes I will try to make punches of the right size on the lathe.
So in summary, unless I find something more serious wrong with it, I think this compressor will be restorable, and should then be a good machine. Even if something more serious does show up, I have a second one of these that I can strip for spares if necessary.
Thanks - Rowan
Hi @rowan_bradley
As most guides found on ifixit are created by users such as yourself who are interested in fixing their devices etc, instead of sending them to landfill, how about creating a repair guide as you fix your compressor and posting it on ifixit?
The same with your extension reel if you get it working.
Others in the future will no doubt thank you for doing so.
Here's how to do it Dare To Repair: How To Create a Guide
Cheers
Moderator.
Rowan Sylvester-Bradley crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 477
