Breville BKC600XL Water Overflowing Cup
Suddenly, when brewing a cup of coffee, the water continued to run for several seconds after the cup was full. I tried all the cup sizes with the same result. I cleaned, descaled, reset the settings, and unplugged overnight. The problem continued. I unplugged the Breville and bought a replacement (Keurig). I used the Keurig for three days but, as the coffee was awful, I decided to use the Breville again until I could find an acceptable replacement. To my surprise, it's now been working perfectly for two days.
I'd like to know what caused the problem and how it righted itself, and if there is a fix if it occurs again and doesn't right itself.
Thanks, with hope!
I hope this explains a what/why on what may have occurred. My recommendation is, if it's no longer playing up, leave it.
A rare occurrence with breville coffee machines is having the water pump flow when it shouldn't. The worst scenario I have heard about (from a tech, but not me) was one that would turn itself on, run the pump until all the water was gone. It's very uncommon, I only know about it affecting Breville. Breville is also marketed as Kambrook, Ronson, and in the UK 'SAGE'. What you're describing sounds like this, but impossible to say for sure. For the record, I love breville coffee machines, i've owned 4.
The issue is with a leaky electrolytic capacitor in the power supply board, combined with the soft-start standby mode. Replacing that caps corrects the issue.
That was 11 years ago for me, wow. Here is a post I added to about it. https://siber-sonic.com/appliance/800Ele...
Good thanks for your collaboration... I have a Brazilian coffee maker such a model... I had to move and I left it stored for a long time. It doesn't turn on at the moment, what could it be? Breville technical service tells me that it is a model that is discontinued and there is no question service, service, CTC answers...
thank you so much
Appliances which don't turn on at all have power supply issues. I'm referring to completely dead and non functional, and no different to being disconnected from the power. These issues are not a part of the rest of the machine. Ie: a coffee maker PS issue is not connected to the grinder or the water pump. There is no way to diagnose a PS issue from a text-comment. Without knowing intimately what the PS looks like, I could not guide you through any steps. Furthermore there is a danger to poking around and I cannot be there to guide you, and I don't know what it looks like, so I cannot give you any quick tips. Even if I could/would, there could be anything causing a PS problem, any one of a thousand different things (until I know what it looks like).
Any thing you fiddle with inside the PS is potentially dangerous. It could injure you, or worse, someone else. It could damage the machine even more, or worse, damage something else. I would love to help you but there isn't a way I can do it.
Vivienne Simmons crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 279
