JBL tuner dab/fm is Frozen
I tried to do a factory reset on my JBL tuner. I plugged into my acer chromebook. Everything was going fine until I was going to eject. I must have clicked in the wrong place , because the usb connection dropped. Now the display shows : " No update file" My speaker will not respond in anyway, regardless of which codes I try. Also it will no longer connect by usb.
Well the saga continues.
I let my speaker stand for two and half days until the battery was empty. I then charged it up - With a full battery I once again tried to do a factory reset. I powered up the speaker. Took my very best usb cable and plugged into my acer chromebook.Once again I received the message about the update. This time I was very careful where and how I clicked.I proceeded thus; alt+right clicked. The correct sub menu appeared. Eject usb.
This I did. But to my dismay, instead of switching off , I once again watched the same message appear on the display.
" No update file " and as before it was frozen. It would not power down or do anything ,regardless of which codes I tried to enter.
But I am very stubborn and will not give in. The battle of dominance continues. This little jewel will conform.
.Resistance is Futile !!!
Disconnect from the laptop, press and hold 4 buttons at once, {DAB/FM} + {VOLUME-} + {BT}+{VOLUME+}, worked for me.
You are a genius…this tip was very helpful to us. Thank you so much
Piepmatz 83
Ich hatte heute das gleiche Problem beim JBL DAB Tuner 2: Batterie voll, aber trotzdem "Nichts geht mehr". Dann suchte ich die kärglichen Bedienungsanweisungen. Dort fand ich in Klammern im Kleinstdruck: Reset auf Werksauslieferung: Blutooth und 1 gleichzeitig mindestens 10 sec. drücken. Hat funktioniert!
Ich hatte das Problem mit dem JBL Tuner XL, ich habe ewig an Einschaltknopf gedrückt, BT+Preset1 wie im Internet beschrieben .. nichts.
Nun habe ich einfach mal BT+DAB/FM gedrückt, dann ging er an .. fantastisch :-)
Danke iFixit, durch den Besuch hier kam ich auf die Idee ;-)
gary wicks crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 50
crwdns2942667:0crwdne2942667:0 1,077
