Ok this unit will draw about 13amps (if your supply voltage is 120v) so it's worth checking your outlet can supply that amount of current in the first instance, it sounds like your first outlet couldn't and you now have a break in that circuit and the heat from the current draw has melted the supply cable, if the unit has lights and is plugged into an outlet which can handle the power draw and the lights don't illuminate then check the fuse. If you replace the fuse and it blows again or the unit simply won't heat then the element is busted
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
0
Now, I can't get it to turn on at all and it is cooled down. The GFI keeps tripping and the first outlet I used is not working at all(that will need to be repaired).
crwdns2934271:0crwdnd2934271:0 amylangleymitchell crwdne2934271:0
