The sixth generation of the Subaru Legacy made its debut at the 2014 Chicago Auto Show, and went into production for the 2015 model year.
check engine light on code p700.
i got this check engine light everytime it rains . i scan the code and it show p700 . ( transmission failure ) however the car run okay no problem and after 2 days of doing running the check engine light will turn off.
See if the diagram here helps. It's from the Outback Owners site.
https://www.suoutback.com/transmission_h...
It could be a number of issues but when you said it mainly happens when it rains then i would put money on it being a bad connection in the wiring harness to the transmission. Maybe water causing a short circuit & then once it’s dried out the transmission control unit thinks the fault has cleared.
I would follow the wiring harness from the left side of the dash, through to the gearbox. Checking for any breaks in insulation & also the security of any connector blocks outside of the interior of the vehicle. I know the Subaru Forester has 2 BIG connector blocks on the top of the gearbox around the bell housing area. It maybe the problem lies in those. Google your transmission wiring harness & see what the photos show you.
Good luck
EDWIN CHAN MENCIAS crwdns2934231:0crwdne2934231:0
crwdns2959996:0crwdne2959996:0 642
