Repair guides and support for the Galaxy Tab S6, released in August 2019. Model number: SM-T860NZAAXAR
Pogo charging stand for S6
Any body know if they can be repaired? They're out of production. It will not charge if the tablet get touched. I use it for streaming and you often need to touch the screen to indicate what you need to watch. Other times it will show charging, but the power level on the battery will continue to drop.
What's wrong with the stand?
It really depends wether the charger you're using is wireless or via USB.
If you're using wireless charging, the adhesive on the charger that holds the magnetic coil vertically might if had the old degraded adhesive treatment which could move the wireless charger out of alignment for the tablet to read. And everytime you tap the charger, it moves the tablet a little meaning it wont be read easily.
On the other hand, if its the USB port you're using, this could be a problem with the tablet accepting the USB port. It could be a mixture of it not supplying the right current anymore or the USB port being doddgy and moving too.
I also dont see why you need that specific stand - there are tons of third-party charging stands out there....
Zed Child crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 212
