Released November 2020, the PS5 console features vastly upgraded visuals and an innovative new Dualsense controller. The space-age black-and-white color scheme is a noticeable departure from PlayStation designs of the past.
Blown capacitor on PS5 affecting display output?
I have this PS5 that came into my shop for a routine HDMI port replacement which went smoothly until I tested it. I plugged it into my Sony TV which immediately recognized that a PlayStation 5 was plugged in and powered on (it changed the name from HDMI 2 to PlayStation 5). SO I know that the PS5 is sending a signal to the TV but that is the end of it. I went back and double checked my port and it looks great.
I then noticed a slight burnt smell. I started investigating and I found what I think is a blown capacitor on the motherboard underneath where the heat sync plate is. My question is: is this component blown? And if so, where can I get another one?
Yes, this is a blown component. Unfortunately, I don't know the value of this component so I can't suggest a replacement.
Good to know, at least I've got a starting point for the next step! Thanks for your input @andrewsawesome !
Has any one had an issue with a PS5 blowing the HDMI board on a Sony A9G?
I don’t have a definitive answer, but using some critical thinking I think you can probably get somewhere in the right neighborhood.
It’s definitely a blown component and I would bet money that it’s a capacitor. If I’m looking at the right spot on the board, and I’m guessing I am based on your description, since you said it was under the backplate for the heat sink, this is a capacitor on a processor power line. It looks like it’s on the same line as the other capacitors beneath it, if you follow that sort of wavy trace in the picture from your post. I would wager that the other caps in that same row will be the same value. Obviously this is not a given, but I would consider it a strong possibility.
That being said I would check 2 things with a multimeter. Is this line short to ground or is this line open/broken somewhere? If it’s short to ground, or generally has very little resistance to ground (which may be normal for this line anyways if it is in fact part of CPU, or more likely given your symptoms, GPU power) I would be very confident this is a cap. Evict the ugly cap from the board and see if that resolves the issue. If it’s open, this may not be a cap at all. And then you’re actually going to have to figure out what it is and what the values are.
If it is a cap, you may be able to leave this it off altogether, but given that it’s not your personal device and it’s more than likely part of CPU function, replacing it would certainly be preferable. I would check voltage on the line if possible when the device is running. And measure capacitance on the other components beneath it (If you have a meter that can do that). Best case scenario would be to pull that cap off a donor board and transplant it over (carefully, since the CPU is directly on the other side), but I realize that’s not always possible in the immediate.
You will need to take measurements and find the 4 digit smd capacitor part number. The identifying marks are dimensions and color of the capacitor. Same color and size, same value.
Try 0501smd Caps
Blake Horsfall crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,888
