PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
Water damage for 5 seconds
My little brother dropped the controller into our fish tank and The controller was in the water for like five seconds and now it won’t work. Is it a good idea to let it sit outside to dry or should I let it inside to dry? And can you give me any advice on how to fix the controller.
Don't use it.
Ideally, you want to open this up, because if you simply let this dry out, you'll usually get corrosion on components.
Clean the board with isopropyl, as this will remove any corrosion and dispell any moisture. Let that evaporate off and test.
If no good, test with another battery, and then check board for blown components if a new battery is no good.
Michael crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 54
