The General Speedrooter 92R Drain Cleaner is an auto-feed drain cleaner 100' x 5/8" from General Pipe Cleaners. Released in 2010. Model number: HDPS92EO.
rescue a 5/8 cable
I have a 100’ drain snake that kinked about 15’ in from the tip, so I cut the cable back and used a quick fix to replace the end. Is there a way I can connect 2 cables together to replace the piece I cut off? rather then replacing the whole cable.
General Pipe cleaners has a "Quick-Fix" tip replacement you can purchase.
JT Hess crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 300
