Are base battaries compatible between 1835 and 1832?
I own a SB2 13.5 model 1832 and the base battery doesn’t hold any charge. it won’t turn on without a charger.
The only replacement base battery I can find is for the 1835 model. would it work with the 1832 model?
Did you replace the battery with the 1835? and did it work?
You can check it by reading information about the wattage on the batteries. Compare the power between both the batteries. If there is the same watt and volt, then you can use it.
mohammud Ali crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 789
