Released September 21, 2018. Models A1920, A2097, A2098, A2100. Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray. (Pronounced "iPhone 10 S.")
Phone turns off taking a photo
To give a bit more detail I have an iPhone XS that doesn’t always turn off but every so often when taking photos will cause it to shutdown even if it has battery it then won’t turn back on until you provide charge (like a jump start) after receiving a brief charge it comes back to life and doesn’t do it again for a while. I can replicate it if I take sometimes 10’s of photos sometimes 100’s.
The only thing I’ve changed is the battery which is on its third now however the most recent was from ReplaceBase so decent quality. I can’t find any panic logs to show what’s happening.
I have the same issue but its mostly in warm weater. But not always. Also, in snapshat, for example, you have to hold the phone still when taking a photo because otherwise the picture is blurred, since the “correct” photo from the beginning is not used.
Were you able to fix the issue?
Does your flash light still work?
It does yes, from what I can tell after a bit of testing no issues here e.g. no turning off of phone after turning it on and off a load of times.
I'm thinking it has a short circuit in the camera. Try switching cameras inside. Either this or either you have a motherboard problem.
'Decent quality ', I have fitted countless bad batteries from replacebase. I'd ask for a replacement and try again.
Andrew crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 1,068
