Is anything on the screen, i.e. is it completely black, or does it light up?
The change of the AC adapter color without a battery installed could indicate that the AC adapter is bad, or that DC-in is bad. You might try a different AC if you have one available, and see if the color change occurs with the other AC.
The first thing I would do is try to reset the PMU by connecting to AC without the battery installed, and holding the power button in for ten seconds. You should get a tone, and then see the sleep light flicker. I would also remove the Airport and extended RAM before doing this, just to simplify the situation.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
2
