4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
Replaced battery, iPhone crashes after a few minutes
Hi! So i recently got a battery to change the 70% original battery health on my iPhone SE. I am not sure what the problem is, but after connecting the battery and the cables on the logic board (and NOT putting the logic board or battery connector shield or the home button cables, so i did not fully close the phone,because i want to test if the battery works properly and if the phone works properly), powering on the iPhone seems to work properly and the phone works as expected. However, using it for roughly 3 minutes, the screen turns black, the iPhone turns off and then it restarts. When i wanted to check the battery health, it just keeps loading until it eventually crashes. the battery percentage also seems to not go down, until it crashes, then when it eventually restarts, it drops by about 5%. What might be the reasons for the crashes? Are the Shields for the logic board and battery needed for the iPhone to work properly? Is there a bug maybe that whenever the percentage number goes down, the iPhone crashes? I know these may be a lot of questions but i’m trying to troubleshoot this to the best of my ability. Any help is appreciated, thanks in advance!
This behaviour is caused by a resistor that has been nudged or knocked off. It is located near the battery connector and will need microsoldering skills to replace.
Is it possible to replace this part rather than microsolder it? I do not have the necessary tools nor skills, and I don't know if there are repair shops who can do the procedure in my area.
@rxjuday Either way it needs to be soldered back on. If you cannot do it yourself I would consider upgrading the phone due to its age and what the repair shop will probably charge.
Hi Chris @imicrosoldering ,
I saw your expertise, I would like to know if you could help. I have a similar problem with iPhone mini 13 . Replaced the battery not OEM and didn't screw back the plates. Worked fine for a few days. Then I tried to screw back the plates and now the A15 bionic chip gets hot and overheats and reboots. It also happens when I put back the original OEM battery back,the chip gets hot.Could you help me where to find the resistor or where to look at on the iPhone 13mini? Any help would be appreciated.Thank you so much
rxjuday crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 739
