How do I replace my microSD card slot?
The thing just isn’t retaining my memory card, and I think it’s done for. How do I replace/repair it?
crwdns2944067:06crwdne2944067:0
Do you have a hot air station?
nope
i guess i'll just replace the motherboard
i'll need to back it all up
@andrewsawesome what if i did?
@notnice -96 If you were able to find a replacement microSD card slot, you could use a hot air gun and flux to heat the solder around the microSD card slot, then remove it with tweezers. You would then tin the pads(put solder on rhe pads with a soldering iron) and heat up the board for the new microSD card until it goes into place.
I think you will just have to use this: Galaxy Tab 3 8.0 Motherboard
It is out of stock right now. This guide should help with that: https://www.ifixit.com/News/56864/findin...
crwdns2886500:0Replace a corroded or malfunctioning main circuit board assembly, including the microSDXC slot, for a Samsung Galaxy Tab 3 8.0.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$29.99
cheers m8, i have another samsung tab 3 that i could cannibalise
i just practiced disassembling it
notnice -96 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 265
