Repair guides and support for videocassette recorders including Betamax and VHS (Video Home System) players.
JVC HR-D721EN black image only sound
hello, from uruguay
I have two vhs jvc version HR-D721EN and both play with sound but black image, I already cleaned the heads and it's still the same, if I fast-forward there you can see the rain but then it's black with the play logo. any idea how to repair it or a circuit that is wrong.
here a picture
thanks
spanish:
tengo dos VHS jvc HR-d721EN, y ambos cuando pongo un casette a reproducir solamente se oye el sonido con la imagen en negro y cartel de play, ya le limpie los cabezales y sigue igual, bloquea la imágen
si le reproduzco y adelanto ahí si se ve la lluvia como que quiere verse pero luego vuelve a negro, alguna idea de algo que este mal para reemplazar
gracias
In all likelihood it a dirty Video Heads problem. Did you use a 'Wet' type Head cleaning cassette?
Yes, I already cleaned the heads and it continues the same
How did you clean the Heads? Did you use a Wet Cleaning Cassete, or a Dry Cassette?
Sometimes Cleaning Cassettes are not very succesful in removing the dirt on the video heads. The head has to be Manually cleaned, using a chamois leather cloth and iso-propyl alcohol.,
maricelada crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 173
