Is it possible to replace the complete body
Hi,
Complete body is broken. Need to know if possible to change complete body.
Hi,
Hi,
You should be able to.
Here’s the hardware maintenance manual for the laptop.
This details the necessary pre-requisite steps and then procedures to remove/replace all of the components from the laptop.
On p.72 -77 there is a parts list which will help you to find the necessary case parts:
base (Item #18 - part #31044218)
upper assembly (Item #4 part #31044216)
lid (Item #6 - there are 4 part # depending on type, part # 31044223, 31044224, 31044340 and 31044341 - usually the part number can be found somewhere on the part itself it you wish to verify which one you have.
thermal door (Item #22 part #31042374).
Search online using the part number only in the search box of your browser to get results for suppliers that suit you best.
It’s certainly possible, though it may be difficult to find parts for at this point, since this machine is 10+ years old. I usually recommend checking with lenovo for part numbers, since that helps make sure you’re getting the correct parts. They will often have pictures to reference. I didn’t see the Z560 in this list but it may be identifiable using the exact model number or serial number if you have those.
crwdns2942667:0crwdne2942667:0 542
