Here you will find several different repair guides for the Dell Chromebook 11 (CB1C13) - 2GB & 4GB models
Dell Chromebook 11 CB1C13
Okay I have two of the same model Dell Chromebook 11 CB1C13 l managed to get one working and powerwashed it, the problem is with the other, both were enrolled in local school and I can't get into developer mode, keep getting message the admin has disabled dev mode, is there a way to get through this? Any advice,ideas or comments are appreciated, what else is possible? thanks
After a powerwash, run through the prompts that are presented in regular usage, set up wifi, and allow the machine to contact google. If the device has been legitimately sold off, the enrollment should drop, and regular login and guest mode should show up in the bottom left corner. If this works, you can then set it to developer mode.
If not, you can wait, try again in a few months, but it is likely that the machine was marked stolen at some point.
Bubba crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 153
