Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
Failed Recovery after battery replacement.
Hey all, hope the new years was good. I’m off to a rough start and now my phone might be bricked after this morning.
I successfully replaced my phone’s battery with a 2225 mAh NOHON and everything went great, however, my 3d touch was buggy on the iphone’s left side - where the battery is located. So this new battery’s pushing against the digitizer (cool). I swap it out with an Apple OEM iphone 6s battery.
The Apple logo flashes. Then it lingers on and off… then it stays on.
I swap out that battery for the NOHON since it worked earlier, but it’s still stuck on a Apple logo. I also put in a new Taptic Engine as a hailmary…uh lmao. Sadly, 3uTools cannot Retain User Data restore nor a Quick restore due to a possible NAND error.
Always hopeful; any suggestions would be appreciated before CONCEDING to another phone. Should’ve listened to my instincts and do a backup, but that’s show biz baby!
Hi there, sometimes you can have issues with the front camera and proximity sensor when they have been damaged when taking off the screen, this can cause your phone to bootloop. I would suggest just trying to start the phone with just the screen connector and touch ID connector plugged in.
Thanks for the suggestion Hamish! Although it didn't work.
The phone did heat up quickly with the NOHON batterey btw and though it can enter recovery mode + DFU, there's a red dot next to the three ribbons.
If that's water damage I have no idea how since it wasn't near any water the whole day. Idk but I'm still holding out
What error do you get when you put the phone in recovery with the original battery and attempt to update through iTunes? (Avoid the non-standard batteries, those are always problematic)
ZigaTon crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 105
