Fit second ssd drive?
Hello all,
I’m sure this has been covered at some point but I just want to be certain of my information before I take apart my iMac.
The iMac came supplied with a single solid state drive which I assume is connected to the SATA connector which is visible immediately when the screen is removed. This is an assumption on my part.
I was hoping I could fit a Blade type SSD (NVME or M.2) to the logic board but I can not find any definite information as to whether this model iMac carries a logic board that will allow this if it has already been supplied with a SSD (500Gb) when delivered.
Has anyone fitted a second SSD on a late 2014 model iMac that already contains a single SSD? Was there a slot available on the logic board? If so can you think of anything else I need to consider before opening my iMac.
The processor is an I7 quad core.
Thanks in advance for any advice that can be offered.
David
