Released on July 28th, 2017, The New Nintendo 2DS XL is a technologically-improved remodel of the 2DS handheld. It is the ninth and last redesign of the Nintendo DS line, The console is much larger than the original 2DS model and adds all the features of the updated 'New 3DS' line of systems, minus the ability to play games in 3D on the top screen.
Why won’t my system read cartridges
Every time I try and play a cartridge game, it never works I also hear this grinding sound, I have no idea why this is happening, can someone please help
it makes the grinding when on and sitting on a flat surface?
there are no real moving parts in the console so it seems like the grinding would be coming from the speakers probably.
No, it’s when I put a cartridge in on any surface
You can try replacing the cartridge slot. The grinding might be coming from thing on the pins or in the slot itself.
Before replacing the slot, you could try a trick to clean the card reader pins first.
  • get some isopropyl alcohol and thoroughly soak the contact points of any cartridge with a Q-tip.
  • put the cartridge in the slot and insert/eject the cartridge repeatedly for about 3 minutes.
  • try it again and see if that fixed it.
hope this helps!
John Bitzas crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 287
